so i pulled the top of the carb off and pulled the idle jet out emulsion tube out and blasted everything with carb cleaner. then blew the piss out of the passages with carb cleaner. then reassembled it with a new float cut off.
it idles about the same if the vacuum port is open or blocked, maybe a 50rpm difference at best. frankly it might as well be my imagination. so i let it idle for about 15 minutes. the good news it is stays cool. the odd news is the longer it ran the higher the idle RPM got. after about 5 minutes it was up to 800. occasionally it would start to idle ruff so i would open the throttle up, get the RPM up to around 3000 and hold it for a few seconds. when i let off the idle would be smooth and at about 800. and based off the smell it's idling a little to much on the rich side. weird cause iv got a 55 idle jet in it right now. so im letting it cool off and ill try a 50 and see what happens.
it's also fluxuating voltage at idle. sometimes its down about 11v others its up over 12. if i disconnect the battery at idle the engine dies. so i don't think my used alternator works worth a shit. i should have tried it with the engine up at a higher RPM but didn't.
alright, after not touching this thing sense like October i did a thing. well more accurately i spent some money. hit up TMI and ordered seat upholstery. went with Saddle vinyl with Sand Tweed Cloth insert.
TMI isn't far from Wolfsburg West, so when i go pick up my upholstery ill swing by there and get the OG style hair seat pads and probably some other odds and ends.
and to think, im only 2 years behind schedule on this job!
Oh man. that's way behind.Super_Randy wrote: ↑May 28th, 2025, 8:51 pm and to think, im only 2 years behind schedule on this job!
for me its par the course. it'll be fine.schwim wrote: ↑May 29th, 2025, 9:50 pmOh man. that's way behind.Super_Randy wrote: ↑May 28th, 2025, 8:51 pm and to think, im only 2 years behind schedule on this job!
I'm pretty sure I'm over a decade late now.
as of the end of October this year mine will have been sitting for a decade. progress has been made and i did get to drive it for about a half hour 2 years ago. but it's been in the backyard for 10 years!
I guess we're neck and neck. Like a slow race on bikes when you were a kid.Super_Randy wrote: ↑May 30th, 2025, 8:45 pm as of the end of October this year mine will have been sitting for a decade. progress has been made and i did get to drive it for about a half hour 2 years ago. but it's been in the backyard for 10 years!
I got to drive mine for even less time. I drove it for a bout 5 minutes, went and tagged and insured it then after rebuilding the fuel pump due to a cracked diaphragm, it started overflowing the fuel bowl, too high pressure now. I've got a couple extra gaskets to put on the stand to get the pressure down.
i did a thing. ok not really. well kinda. i drained the 2 year old commiefornia gas out of the tank over the weekend. mower seems to run on it fine. but i also stopped by TMI and Wolfsburg West this morning.
- Attachments
- 1.jpg (3.31 MiB) Viewed 29232 times
- 2.jpg (3.69 MiB) Viewed 29232 times
- 3.jpg (3.66 MiB) Viewed 29232 times
They look fantastic. I really need to bite the bullet and do the same. Sitting on 70 year old horsehair kind of blows.
