149 posts Page 14 of 15
Previous 1 ... 11, 12, 13, 14, 15 Next
Thank you for the kind words fellas! :)
July 2011 (cont'd)
High time to get the engine ready.
The oil pump cover was a bit leaky so I replaced the seals and nuts...
The plan was to paint the areas of the engine case that are exposed to the engine bay.
I used a soft rotary wire wheel brush to carefully clean & prepare the magnesium alloy for the coating.
While changing the spark plugs things turned nasty...
The last one (#4) didn't unscrew as smooth as the others. :?
The thread wasn't clean and shiny but all smudgy and glazed. :shock:
A closer inspection of the tap hole in the cylinder head revealed some structures that very much looked like a crack! :(
Damn! It wasn't planned to take the heads off since the engine ran quite well but I had to find out what's going on...
So off with it's head! :D
Here we go - one nice crack!
That was quite a body blow - the plans for the driving season moved beyond reach... :(
Unfortunately Riechert didn't provide machined & ported cylinder heads any longer so I had to find another supplier.
For the time being I proceeded with partly coating the engine case using Brantho-Korrux 3 in 1...
And last but not least Riechert sent back the overhauled and tuned carbs...
August 2011
New cylinder heads were on order, time to put the rear end together.
Final layer of undercoat applied to the rear apron...
Attached the fenders...
Bumper, taillights as well as new engine bay and deck lid seals installed...
Thought it would not hurt to brush up the generator stand and oil filler...
September 2011
Removed the remaining cylinder head, the cylinders and the pistons.
While at it I took out the flywheel main seal and checked the end play.
New flywheel main seal installed...
September 2011 (cont'd)
Cut new cylinder base seals using Reinz AMF 30 0.3mm gasket sheet material
Sealing surfaces & stud bolts cleaned, new seal fitted to the cylinder base...
Reinstalled cylinders 3 & 4 with pistons...
Finally the new heads arrived...
Well then - put these heads on...
We have a long block... :)
Put the clutch back together...
Installed the push rods and rockers...
Valve train completed...
October 2011
Engine tin in place...
Test fitted the new stainless steel exhaust. Looked good at first glance...
Now get that motor in...
Engine bay almost complete - just a few bits still missing... :)
Wow, that looks so clean! Do you find it easier to handle the cooling/charging system after bolting the engine in?
schwim wrote: Do you find it easier to handle the cooling/charging system after bolting the engine in?
Yes with my engine set up (front oil cooler & dual carbs) this approach is easier IMHO.
Due to the fact that the original oil cooler is replaced by the way smaller oil thermostat the slightly
modified fan shroud can easily be fitted with the engine already in the car.
Hence the Bug needs to be lifted to a much lesser extend to get that "flat engine" in.
It's also more comfortable to mount the intake manifolds before the shroud goes in.
Below is a pic of the modified fan shroud. The needles dog house duct is blocked by a tin inside.
You can get a glimpse of that metal sheet at the hole for the accelerator cable lead through.
I cut out the lower portion of the dog house chamber to be able to put the fan shroud over the
thermostat assembly and stay clear of the deck lid hinges.
March 2012
Hey, wake up - hibernation's over!
Intake manifolds with equalizing pipes installed...
Fan shroud fitted...
Generator and carburetor linkage mounted. Again I turned a blind eye to possible cooling issues... :roll:
Almost done...
Well... Although it looked good while mounted to the engine on the bench,
that Memminger exhaust actually did not mesh with the rear apron... :(
Phoned Memminger Senior regarding the issue but he refused to exchange the poorly welded exhaust. :( :(
Instead he advised me to either
- loosen the transmission mounts and rotate the whole power train until the tailpipes fit the rear apron,
or
- using the bulged rear apron of the later models - "that way the misalignment doesn't attract attention".
:shock: :shock: :shock:
So much for that! Form your own opinion...
The only reason why I kept that Sebring/Memminger botch was the fact that it's TÜV certified and street legal.
Now I have to find a way to fix that mess...
Who is online
Users browsing this forum: schwim and 3 guests
cron
